Testing version: Version 2.0 (10084)
What were you doing: The info column always opens as a pop-up window on my 14" MacBook Pro M1 despite various window adjustments including closing both notes and tags views.
Yeah I noticed the same behavior on my 13.3" M1 Air and can’t find a window setup where the column would appear. Not even setting the display scaling to the one with more space helps.
Have you read the new beta notes when it got released? I overlooked it too, but it says the Info column isn’t implemented yet.
The current beta doesn’t include the 4° column because we struggled to find a design that works with the editor (and the rest of Bear). Luckily we found a good solution.
Oh, right. I did read it but apparently missed this detail. Thanks.
