Testing version: Panda Writer (iOS) Version 0.1 (1571)
What were you doing: I selected text inside of a table.
What feature did you use: I used the iOS selection method for text.
What happened: When the menu appeared over the selected text, the option “Insert Space Above” was also in the options. However, tapping on this option simply deletes the selected text.
What did you expect to happen: I didn’t expect the “Insert Space Above” option to appear when selecting text in a Table. I assume it is an incorrect menu option which should only appear in the Sketch options within bear. I assume “Insert Space Above” is a function reserved for Sketch and is part of PencilKit.
