Testing version: 2.0 (11015) Mac
What were you doing: Clipping content from the web
What feature did you use: Web clipping in browser Arc
What happened: A windows shows up every time to ask me to open Bear (when it’s actually already open)
What did you expect to happen: Clip content in a note an not interrupt the workflow
Thanks!
If you click on Always open "Bear"
the panel shows again the next time you use the extension?
Correct, both those buttons behave the same way. It will reappear the next time I clip something in the same browsing session.
@trix180 Is it something fixable? thanks!
@trix180 I am available to provide additional information to assist you in replicating the issue. All the best!
I still struggle to replicate this issue. Doesn’t seems like something we have control of as the extension code is pretty barebone. Which macOS and Safari versions you are running?
I am able to replicate the problem. I use Arc too. Version 0.103.1 (38943)
macOS Ventura 13.3.1 (a)
