Links can be underlined not always working
Testing version: Version 2.0 (9735)
What were you doing: Trying to underline links
What feature did you use: Command-U
What happened: When I hit this shortcut on a link of a single word in the title header of a table I had created minutes before, it worked. When I tried underline a link in a note that I got imported earlier from B1, it did not. The screenshot shows what showed up.
What did you expect to happen: Underline to work with “old” links as well.
I also see that the new fix only underlines the implicit outward links and donmt work with only the urls or the wikilinks.
I can confirm We allowed underlining only to the MD links and we forgot wiki links and automatic links. We’ll fix this with the next update.
You forgot?
You probably don’t know this, but there’s a very good note taking app. It is beautifully designed and has just the right features, including a nice list. You really should try it out. It’s called Bear.
:grin:
:laughing: I’ll give it a shot
