Testing version: Version 1.0 (1648)
What were you doing: Indenting a bulleted list two levels deeper than the parent
What feature did you use: Indentation
What happened: Nothing.
What did you expect to happen: The bulleted list to move one level deeper
Hi all, unsure if this is intentional. But I am no longer able to nest bullet points arbitrarily. Bullet points must be exactly one level away from parent.
This creates some odd-looking text if I choose to delete a parent, and leave some grandchildren bullet points lying around.
