Testing version: Version 1.0 (3096) MacOS 12.6 (21G115)
What were you doing: use right click look up on word in a table
What did you expect to happen: Show the look up
Hello, and thanks for reporting this issue.
Hi, I would like to add another thing, Grammar & Spelling checker does not work inside table as well. Currently doing a workaround by ‘breaking’ the table withe triple tick, running it through, amending it, and removing the triple tick to go make it back to a table. Thanks!
