Version 2.0 (10984) on macOS 13.3.1
- Tapped the Info icon in the top right
- Dragged the info window to tear it off (i.e. detach it)
- Dragged to position the info window at the top of the screen (just below the macOS menu bar)
- The detached info window cannot be positioned right at the top like the main window can.
Attached image shows the Info window (showing Table Of Contents) which I’ve positioned as high as is possible vertically. I expected it would be possible to move this window just below the menu bar but I can’t - a gap always remains.
(I sent this issue via Testflight feedback, but then realised that you prefer the reports via this forum instead - apologies if you’ve seen this twice).
