Mark/highlighter formatting ignores todo styles
Testing version: Version 1.0 (362), macOS 10.13.6
What were you doing: Marking a todo completed
What feature did you use: Combining Highlighter and Todo functions
What happened: Mark/highlighter styles aren’t affected by the todo check-off. Instead of graying out, they stay the same.
What did you expect to happen: Some sort of faded completion style applied to Highlighted-formatted text
todo-completion-highlighter
It seems that any formatting that changes text colors doesn’t change appearance inside a checked-off todo:
completed-todo-text
Yep this is a bug :smiley:
We’ll probably wait for the final decision about checkbox style and then we’ll fix this.
Thanks!
