Markdown requires that items such as headings, lists, etc. be separated by a blank line.
Panda’s markdown file does not have blank lines after such items, even though the note preview is stylized with separation that suggests otherwise (i.e. padding is added automatically between headings and whatever follows).
Note in Panda:
Same note, in a text editor:
There should be a blank line between Heading 1 and the list below it, as well as between A paragraph. and Heading 2.
Is this intentional? In order to have proper markdown formatting, do I need to manually add extra lines in Panda, so it looks like this?
To me, this feels like it would ruin the preview formatting that Panda does so well.
blank lines before/after headers are not required in Markdown and you’re free to follow the style you like more (with or without).
Panda typography was built around both possibilities: adding a bit of space if you don’t want a blank line after the header or just showing a blank line without the additional space.
There is no right or wrong here is just a matter of preferences
