Navigating through notes by Command + Option + Left/Right arrows — NOT WORKING
2.0 -10936
Trying to go back to last edited note by keyboard shortcut
It never worked in any 2.0 version
Navigate back and forward through the notes you have recently viewed or edited
You could use
  • Command + [ for previous note
  • Command + ] for next note
and I think Command + Option + arrows are now also how you can indent/outdent list items. (another way is tab or shift+tab)
thank you, it works in English keyboard only though.
You can check the shortcut localisations in the View menu.
that did it! thank you very much
