Note multi-select
At this point is there a way to multi-select notes?
Sure! You can select multiple notes both on macOS and iOS:
macOS: click on multiple notes while keeping the ⌘ key pressed
iOS: use the standard two finger pan gesture to start the multiple selection
Thank you. I am making templates with a tag called (you guessed it “templates”) and I have some nested tags and wanted to select all notes within that tag structure to duplicate then change the tag(s) for the newly duplicated tags and for the life of me I could not figure out how to select multiple notes.
