Opening a note through Spotlight search does not open app
Testing version: Version 2.0 (11208)
What were you doing: Searching for a Bear note in Spotlight and opening that
What feature did you use: Spotlight Search
What happened: The app window did not open. I had to manually click on the app icon in the dock to open the window. However, the note was selected after the search. It’s just that the app window did not pop up.
When the app is Quit and not running in the background, searching for a note on Spotlight and opening it does open the app window with the note selected.
What did you expect to happen: I expected the app window to open with the searched note selected.
Yes, the window should be visible when triggered from the spotlight. Good catch.
