Testing version: Version 1.0 (1563)
What were you doing: Writing up a technical answer on another Discourse forum!
What feature did you use: Lists with code blocks inside of them:
- a list item with some code in it:
```js
function cool() {
alert("This is neat!");
It did not correctly interpret the code block as a block item within the list. Instead, it treated it as an indentation-powered code block:
It should render roughly the same way it does on Discourse:
