Panda crashing on launch
Testing version: downloaded 28.08.21
What were you doing: trying to launch
What feature did you use: none
What happened: app crashes, unable to be launched
What did you expect to happen: something better
Process: Panda [4864]
Path: /private/var/folders/*/Panda.app/Contents/MacOS/Panda
Identifier: net.shinyfrog.panda
Version: 1.0 (2208)
Code Type: ARM-64 (Native)
Parent Process: ??? [1]
Responsible: Panda [4864]
User ID: 501
Date/Time: 2021-08-28 19:06:12.312 +0300
OS Version: macOS 11.5.2 (20G95)
Report Version: 12
Anonymous UUID: 8659A2D3-3275-C694-31D9-544B2B90BF56
Sleep/Wake UUID: F649A66F-EF3E-40B8-BBC6-F09A736CA2F9
Time Awake Since Boot: 6400 seconds
Time Since Wake: 2900 seconds
System Integrity Protection: enabled
Notes: Translocated Process
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: EXC_ARM_BREAKPOINT at 0x000000019f093594 (brk 1)
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Trace/BPT trap: 5
Termination Reason: Namespace SIGNAL, Code 0x5
Terminating Process: exc handler [4864]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libswiftFoundation.dylib 0x000000019f093594 static URL.unconditionallyBridgeFromObjectiveC(:slight_smile: + 160
1 net.shinyfrog.TextBundle-Mac 0x000000010565cc78 0x105658000 + 19576
2 net.shinyfrog.PandaCore-Mac 0x0000000105229acc -[MarkdownCoreDocument coreReadFromURL:error:] + 452
3 com.apple.AppKit 0x0000000192537d14 -[NSDocument _initForURL:withContentsOfURL:ofType:error:] + 196
4 com.apple.AppKit 0x0000000192537f38 -[NSDocument initForURL:withContentsOfURL:ofType:error:] + 320
5 com.apple.AppKit 0x000000019256d5e8 -[NSDocumentController makeDocumentForURL:withContentsOfURL:ofType:error:] + 372
6 com.apple.AppKit 0x000000019256c988 __104-[NSDocumentController makeDocumentForURL:withContentsOfURL:alternateContents:ofType:completionHandler:]_block_invoke + 84
7 com.apple.AppKit 0x000000019256c920 -[NSDocumentController makeDocumentForURL:withContentsOfURL:alternateContents:ofType:completionHandler:] + 188
8 com.apple.AppKit 0x000000019256d00c __89-[NSDocumentController reopenDocumentForURL:withContentsOfURL:display:completionHandler:]_block_invoke + 468
9 com.apple.AppKit 0x000000019256b5c8 __144-[NSDocumentController _coordinateReadingAndGetAlternateContentsForOpeningDocumentAtURL:resolvingSymlinks:thenContinueOnMainThreadWithAccessor:]_block_invoke_4 + 36
10 com.apple.AppKit 0x000000019256b888 __144-[NSDocumentController _coordinateReadingAndGetAlternateContentsForOpeningDocumentAtURL:resolvingSymlinks:thenContinueOnMainThreadWithAccessor:]_block_invoke.793 + 168
11 com.apple.AppKit 0x000000019256b77c __144-[NSDocumentController _coordinateReadingAndGetAlternateContentsForOpeningDocumentAtURL:resolvingSymlinks:thenContinueOnMainThreadWithAccessor:]_block_invoke.789 + 308
12 com.apple.AppKit 0x0000000192575a80 ___NSMainRunLoopPerformBlockInModes_block_invoke + 44
13 com.apple.CoreFoundation 0x000000018f802530 CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK + 28
14 com.apple.CoreFoundation 0x000000018f8023a4 __CFRunLoopDoBlocks + 408
15 com.apple.CoreFoundation 0x000000018f8013d0 __CFRunLoopRun + 1728
16 com.apple.CoreFoundation 0x000000018f800598 CFRunLoopRunSpecific + 600
17 com.apple.HIToolbox 0x0000000197725280 RunCurrentEventLoopInMode + 292
18 com.apple.HIToolbox 0x0000000197724ff4 ReceiveNextEventCommon + 552
19 com.apple.HIToolbox 0x0000000197724db4 _BlockUntilNextEventMatchingListInModeWithFilter + 72
20 com.apple.AppKit 0x0000000191ff1660 _DPSNextEvent + 836
21 com.apple.AppKit 0x0000000191ff0000 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1292
22 com.apple.AppKit 0x0000000191fe1e4c -[NSApplication run] + 596
23 com.apple.AppKit 0x0000000191fb3878 NSApplicationMain + 1064
24 net.shinyfrog.panda 0x0000000104f4ea7c 0x104f48000 + 27260
25 libdyld.dylib 0x000000018f721430 start + 4
Thread 1:
0 libsystem_pthread.dylib 0x000000018f6fe5cc start_wqthread + 0
Thread 2:
Thread 3:
Thread 4:
Thread 5:
Thread 6:
0 libsystem_kernel.dylib 0x000000018f6c8dd4 mach_msg_trap + 8
1 libsystem_kernel.dylib 0x000000018f6c9184 mach_msg + 76
2 net.shinyfrog.panda 0x0000000104f96150 0x104f48000 + 319824
3 libsystem_pthread.dylib 0x000000018f703878 _pthread_start + 320
4 libsystem_pthread.dylib 0x000000018f6fe5e0 thread_start + 8
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000000 x2: 0x0000000000000000 x3: 0x0000000000000002
x4: 0x000000016aeb5f10 x5: 0x0000000000000011 x6: 0x00000001fab3e838 x7: 0x0000000000000000
x8: 0x000000016aeb5d10 x9: 0x000000016aeb5d20 x10: 0x0000600002af6450 x11: 0x0000000000009687
x12: 0x0000000000000001 x13: 0x0000000000000000 x14: 0x0000000000000159 x15: 0xffffffffffffffff
x16: 0x000000019f0934f4 x17: 0x000000010565cc20 x18: 0x000000011389a83c x19: 0x000000016aeb5f10
x20: 0x0000000000000002 x21: 0x0000000000000000 x22: 0x0000600000ec0660 x23: 0x0000600000ec0660
x24: 0x000000016aeb5d10 x25: 0x0000600003ffd5c0 x26: 0x0000600000ec04e0 x27: 0x0000000000000000
x28: 0x0000000105235000 fp: 0x000000016aeb5d60 lr: 0x000000010565cc78
sp: 0x000000016aeb5d10 pc: 0x000000019f093594 cpsr: 0x60000000
far: 0x00000001fad517f0 esr: 0xf2000001
Binary Images:
0x104f48000 - 0x10500ffff +net.shinyfrog.panda (1.0 - 2208) <6531A967-A7B2-3C12-BD05-140C6C8A138C> /var/folders//Panda.app/Contents/MacOS/Panda
0x105058000 - 0x10505ffff +net.shinyfrog.SFCodeHighlighter-Mac (1.0 - 1) <67199BCB-7554-3807-8518-267B55424F5E> /var/folders/
/Panda.app/Contents/Frameworks/SFCodeHighlighter.framework/Versions/A/SFCodeHighlighter
0x105078000 - 0x1051a7fff +net.shinyfrog.MDTextKitUI-Mac (1.0 - 1) /var/folders//Panda.app/Contents/Frameworks/MDTextKitUI.framework/Versions/A/MDTextKitUI
0x105220000 - 0x10522ffff +net.shinyfrog.PandaCore-Mac (1.0 - 1) /var/folders/
/Panda.app/Contents/Frameworks/PandaCore.framework/Versions/A/PandaCore
0x105248000 - 0x105257fff +net.shinyfrog.SketcherKit-Mac (1.0 - 1) <42687134-B9CF-3E8D-BFA1-D7A6FFCE3523> /var/folders//Panda.app/Contents/Frameworks/SketcherKit.framework/Versions/A/SketcherKit
0x10526c000 - 0x10526ffff +net.shinyfrog.Class-Bridge-Mac (1.0 - 1) <3D1F7A32-63F7-36AA-9E19-FB60F8BE85DC> /var/folders/
/Panda.app/Contents/Frameworks/ClassBridge.framework/Versions/A/ClassBridge
0x105280000 - 0x105287fff +net.shinyfrog.CRDTKit-macOS (1.0 - 1) /var/folders//Panda.app/Contents/Frameworks/CRDTKit.framework/Versions/A/CRDTKit
0x105298000 - 0x1052a3fff +net.shinyfrog.SFThemeKit (1.0 - 1) <0CDEFD2D-621D-37B6-AF64-B4B85CE4F879> /var/folders/
/Panda.app/Contents/Frameworks/SFThemeKit.framework/Versions/A/SFThemeKit
0x1052d0000 - 0x10534ffff dyld (852.2) <17D14D9B-B6B2-35DC-B157-4FD60213BE99> /usr/lib/dyld
0x1053d8000 - 0x1054abfff +net.shinyfrog.PolarMark-Mac (1.0 - 1) /var/folders//Panda.app/Contents/Frameworks/PolarMark.framework/Versions/A/PolarMark
0x10550c000 - 0x105557fff +net.shinyfrog.MDTextKit-Mac (1.0 - 1) /var/folders/
/Panda.app/Contents/Frameworks/MDTextKit.framework/Versions/A/MDTextKit
0x1055a0000 - 0x1055e7fff +org.sparkle-project.Sparkle (2.0.0 - 2.0.0) <69D98481-45B0-3A49-BBF3-EA3004ADA528> /var/folders//Panda.app/Contents/Frameworks/Sparkle.framework/Versions/A/Sparkle
0x105658000 - 0x105673fff +net.shinyfrog.TextBundle-Mac (1.0 - 1) <5DB56442-0722-309B-8E9B-4D282BF4F18D> /var/folders/
/Panda.app/Contents/Frameworks/TextBundle.framework/Versions/A/TextBundle
0x112a50000 - 0x112a5bfff libobjc-trampolines.dylib (824) <5ED4E6D9-CDC1-3BFB-885C-EB9537FC0344> /usr/lib/libobjc-trampolines.dylib
0x114584000 - 0x114587fff com.apple.CloudDocsFileProvider (1.0 - 738.1) <9A2B81ED-DE30-308A-A9C5-44DB4D535779> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/CloudDocsFileProvider.bundle/Contents/MacOS/CloudDocsFileProvider
0x11459c000 - 0x11459ffff com.apple.FileProviderOverride (349.4.3 - 349.4.3) <428DF779-27DE-3664-A82D-FA7243FD6DA9> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FileProviderOverride.bundle/Contents/MacOS/FileProviderOverride
0x1145b4000 - 0x1145cffff com.apple.findersync.fileprovideroverride.FinderSyncCollaborationFileProviderOverride (1.0 - 1350.6.1) <87BF96BA-B439-3C44-AA28-52A153006B5B> /System/Library/Frameworks/FileProvider.framework/OverrideBundles/FinderSyncCollaborationFileProviderOverride.bundle/Contents/MacOS/FinderSyncCollaborationFileProviderOverride
0x18f45e000 - 0x18f45ffff libsystem_blocks.dylib (79) /usr/lib/system/libsystem_blocks.dylib
0x18f460000 - 0x18f497fff libxpc.dylib (2038.120.1) <33FB2ED1-AB10-3900-BA93-5767A5086AD7> /usr/lib/system/libxpc.dylib
0x18f498000 - 0x18f4affff libsystem_trace.dylib (1277.120.1) <59FD0CCA-0321-3A28-A2FB-80CCBDDFEC82> /usr/lib/system/libsystem_trace.dylib
0x18f4b0000 - 0x18f523fff libcorecrypto.dylib (1000.140.4) /usr/lib/system/libcorecrypto.dylib
0x18f524000 - 0x18f54ffff libsystem_malloc.dylib (317.140.5) <816E435C-D24C-3EF5-8932-5B7C8EAE4AEC> /usr/lib/system/libsystem_malloc.dylib
0x18f550000 - 0x18f594fff libdispatch.dylib (1271.120.2) <7FAD1391-1E49-3CF2-9936-E808F815AA8F> /usr/lib/system/libdispatch.dylib
0x18f595000 - 0x18f5cefff libobjc.A.dylib (824) <3478ECD1-A8BB-38DC-BC97-966A244DB668> /usr/lib/libobjc.A.dylib
0x18f5cf000 - 0x18f5d1fff libsystem_featureflags.dylib (28.60.1) /usr/lib/system/libsystem_featureflags.dylib
0x18f5d2000 - 0x18f653fff libsystem_c.dylib (1439.141.1) <33167920-470B-366B-8EDC-C138EE669785> /usr/lib/system/libsystem_c.dylib
0x18f654000 - 0x18f6affff libc++.1.dylib (905.6) <95188C52-741C-3F57-A78F-90334F6518B1> /usr/lib/libc++.1.dylib
0x18f6b0000 - 0x18f6c7fff libc++abi.dylib (905.6) <0EB11B11-F4A5-355E-B44C-955ADD774E61> /usr/lib/libc++abi.dylib
0x18f6c8000 - 0x18f6fbfff libsystem_kernel.dylib (7195.141.2) <1E1E6F44-01BC-3994-A907-61288C3D7BFD> /usr/lib/system/libsystem_kernel.dylib
0x18f6fc000 - 0x18f708fff libsystem_pthread.dylib (454.120.2) <85E14929-1F9B-3E79-ABDE-06EB161F9574> /usr/lib/system/libsystem_pthread.dylib
0x18f709000 - 0x18f74afff libdyld.dylib (852.2) /usr/lib/system/libdyld.dylib
0x18f74b000 - 0x18f751fff libsystem_platform.dylib (254.80.2) <17522FB4-6BA9-31D4-8222-699B80714CC3> /usr/lib/system/libsystem_platform.dylib
0x18f752000 - 0x18f77dfff libsystem_info.dylib (542.40.3) <93ED568C-DBDC-3F74-9434-834B5DF0E2EC> /usr/lib/system/libsystem_info.dylib
0x18f77e000 - 0x18fc2cfff com.apple.CoreFoundation (6.9 - 1777.103) <0EE241E3-3A80-3F15-AB1E-B5C18CA7E4B1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x18fc2d000 - 0x18fe65fff com.apple.LaunchServices (1122.41 - 1122.41) <8846ED26-47F7-3C95-A12D-C0187D05059E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x18fe66000 - 0x18ff40fff com.apple.gpusw.MetalTools (1.0 - 1) /System/Library/PrivateFrameworks/MetalTools.framework/Versions/A/MetalTools
0x18ff41000 - 0x1901abfff libBLAS.dylib (1336.140.1) <01B7A91B-31CB-348C-BCAE-DAF215B566C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x1901ac000 - 0x1901f6fff com.apple.Lexicon-framework (1.0 - 86.2) <5F8A23F6-6713-3BC5-A59A-571972D88022> /System/Library/PrivateFrameworks/Lexicon.framework/Versions/A/Lexicon
0x1901f7000 - 0x19025afff libSparse.dylib (106) <02748559-0716-35CC-8E70-22FF91D0CE47> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparse.dylib
0x19025b000 - 0x1902e2fff com.apple.SystemConfiguration (1.20 - 1.20) /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x1902e3000 - 0x190316fff libCRFSuite.dylib (50) /usr/lib/libCRFSuite.dylib
0x190317000 - 0x190545fff libmecabra.dylib (929.10) /usr/lib/libmecabra.dylib
0x190546000 - 0x1908d2fff com.apple.Foundation (6.9 - 1777.103) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1908d3000 - 0x1909c2fff com.apple.LanguageModeling (1.0 - 247.3) /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x1909c3000 - 0x190ae5fff com.apple.CoreDisplay (237.4 - 237.4) <38654CFE-34C0-3A22-88F4-51B7E6CD22A5> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x190ae6000 - 0x190d4efff com.apple.audio.AudioToolboxCore (1.0 - 1181.72) /System/Library/PrivateFrameworks/AudioToolboxCore.framework/Versions/A/AudioToolboxCore
0x190d4f000 - 0x190f1efff com.apple.CoreText (677.6.0.2 - 677.6.0.2) <650DCFE4-3F56-384E-98F3-55E64AD3A824> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x190f1f000 - 0x191539fff com.apple.audio.CoreAudio (5.0 - 5.0) /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x19153a000 - 0x1918a0fff com.apple.security (7.0 - 59754.140.13) <6A354A87-B586-3575-B518-CA046B4A2B36> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x1918a1000 - 0x191b12fff libicucore.A.dylib (66112) <17E0A41B-60CE-3DC1-9842-D6FF595C55FC> /usr/lib/libicucore.A.dylib
0x191b13000 - 0x191b1dfff libsystem_darwin.dylib (1439.141.1) <7E7806F7-0442-3280-97A1-2D6364FAF68B> /usr/lib/system/libsystem_darwin.dylib
0x191b1e000 - 0x191e11fff com.apple.CoreServices.CarbonCore (1307.3 - 1307.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x191e12000 - 0x191e4dfff com.apple.CoreServicesInternal (476.1.1 - 476.1.1) <409DAE8B-1FED-387A-ABC5-0D1866587B82> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x191e4e000 - 0x191e89fff com.apple.CSStore (1122.41 - 1122.41) <724E19B8-926D-3BE2-8577-5B94F7F51E78> /System/Library/PrivateFrameworks/CoreServicesStore.framework/Versions/A/CoreServicesStore
0x191e8a000 - 0x191f55fff com.apple.framework.IOKit (2.0.2 - 1845.120.6) <63CEB2C2-F60A-39BB-BEBD-0255154452CD> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x191f56000 - 0x191f61fff libsystem_notify.dylib (279.40.4) /usr/lib/system/libsystem_notify.dylib
0x191f62000 - 0x191faffff libsandbox.1.dylib (1441.141.1) <6884FD62-5F52-3AAE-91A0-252130D8A729> /usr/lib/libsandbox.1.dylib
0x191fb0000 - 0x192cf1fff com.apple.AppKit (6.9 - 2022.60.128) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x192cf2000 - 0x192f18fff com.apple.UIFoundation (1.0 - 728.9) <11CEEA67-6F89-3C70-AD0C-DE82A772875B> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x192f19000 - 0x192f2bfff com.apple.UniformTypeIdentifiers (637 - 637) <53FB8E62-386B-36D6-95D9-6BAA6ABDD6A6> /System/Library/Frameworks/UniformTypeIdentifiers.framework/Versions/A/UniformTypeIdentifiers
0x192f2c000 - 0x193096fff com.apple.desktopservices (1.21 - 1346.6.1) <2211E581-3372-3D1C-BC73-0189321271EC> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x193097000 - 0x1930a9fff com.apple.metadata.SpotlightLinguistics (1.0 - 1) <8532D9CD-E13B-3B5D-BAF8-4C9AE11C1747> /System/Library/PrivateFrameworks/SpotlightLinguistics.framework/Versions/A/SpotlightLinguistics
0x1930aa000 - 0x1932adfff com.apple.CoreDuet (1.0 - 1) /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x1932ae000 - 0x193362fff libboringssl.dylib (351.140.2) <5577CAA4-E57E-39A9-9712-5951563AA9B1> /usr/lib/libboringssl.dylib
0x193363000 - 0x193aabfff libnetwork.dylib (2288.140.7) /usr/lib/libnetwork.dylib
0x193aac000 - 0x193f34fff com.apple.CFNetwork (1240.0.4 - 1240.0.4) <496FEA2B-9B13-3881-ADB8-AACE980425D7> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x193f35000 - 0x193f44fff libsystem_networkextension.dylib (1295.140.3) <52A5D26E-D9D2-3ECE-8015-B31B1B9F7FC9> /usr/lib/system/libsystem_networkextension.dylib
0x193f45000 - 0x193f46fff libenergytrace.dylib (22.100.1) <1BA088D7-0DAD-3F5E-80A5-5FD4E9EBEBF9> /usr/lib/libenergytrace.dylib
0x193f47000 - 0x193f99fff libMobileGestalt.dylib (978.140.1) <44B6E4D5-AC61-37AA-A775-2F89116772C2> /usr/lib/libMobileGestalt.dylib
0x193f9a000 - 0x193fb1fff libsystem_asl.dylib (385) <55CF534F-17B2-3119-BCFB-A2F945CA3272> /usr/lib/system/libsystem_asl.dylib
0x193fb2000 - 0x193fcbfff com.apple.TCC (1.0 - 1) <28C932A1-B171-36DC-8F03-803A53DB8865> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x193fcc000 - 0x19433afff com.apple.SkyLight (1.600.0 - 588.7) <1E77ED06-C425-38F9-AF4B-8563DEB721C7> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x19433b000 - 0x194928fff com.apple.CoreGraphics (2.0 - 1463.16.1) /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x194929000 - 0x194a1efff com.apple.ColorSync (4.13.0 - 3473.4.3) /System/Library/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x194a1f000 - 0x194a7afff com.apple.HIServices (1.22 - 716) <6C9928A6-55D8-3981-A13F-333DBC62503D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x194a7b000 - 0x194abafff libAWDSupport.dylib (951) /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupport.dylib
0x194abb000 - 0x194b1cfff libprotobuf.dylib (4205) <8AB7A8D9-7DD5-3C6E-BAD5-889EC1CAC51B> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x194b1d000 - 0x194b2ffff libprotobuf-lite.dylib (4205) /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf-lite.dylib
0x194b30000 - 0x194b77fff com.apple.awd (1.0 - 951) <96E7D49B-F37B-339A-A4CD-ECDD059F1C70> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x194b78000 - 0x194ce7fff com.apple.Montreal (1.0 - 142) <387BB01B-E0B8-3768-970D-6B8F5E94A88F> /System/Library/PrivateFrameworks/Montreal.framework/Versions/A/Montreal
0x194ce8000 - 0x194dd3fff com.apple.NLP (1.0 - 210.2) <4A50886F-AD5F-3EBE-98A7-C1F9D7A36343> /System/Library/PrivateFrameworks/NLP.framework/Versions/A/NLP
0x194dd4000 - 0x19517cfff com.apple.CoreData (120 - 1048) <33F455F4-6672-3227-A033-86B6FFCE629A> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x19517d000 - 0x195193fff com.apple.ProtocolBuffer (1 - 285.24.10.20.1) /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x195194000 - 0x195331fff libsqlite3.dylib (321.3) <7FD239FD-B516-37AD-8A4B-510E287523B8> /usr/lib/libsqlite3.dylib
0x195332000 - 0x1953a6fff com.apple.Accounts (113 - 113) /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x1953a7000 - 0x1953bdfff com.apple.commonutilities (8.0 - 900) <00FA48A7-5445-3D7D-846A-CB98A7CE7583> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x1953be000 - 0x195440fff com.apple.BaseBoard (526 - 526) /System/Library/PrivateFrameworks/BaseBoard.framework/Versions/A/BaseBoard
0x195441000 - 0x19548efff com.apple.RunningBoardServices (1.0 - 505.100.8) <109B3867-729F-3569-9173-33B385DD6AEB> /System/Library/PrivateFrameworks/RunningBoardServices.framework/Versions/A/RunningBoardServices
0x19548f000 - 0x195502fff com.apple.AE (918.6 - 918.6) <6747FF69-AF52-38BE-BF25-949838E4CA14> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x195503000 - 0x19550afff libdns_services.dylib (1310.140.1) <2E0F76ED-EF2C-3396-83B6-A51C8B40811B> /usr/lib/libdns_services.dylib
0x19550b000 - 0x195512fff libsystem_symptoms.dylib (1431.140.1) <468E8052-5144-34BE-9923-1185ADDB556B> /usr/lib/system/libsystem_symptoms.dylib
0x195513000 - 0x19566ffff com.apple.Network (1.0 - 1) <0A500CB1-4EA0-3E6A-853D-C2C15C9B0C92> /System/Library/Frameworks/Network.framework/Versions/A/Network
0x195670000 - 0x1956a2fff com.apple.analyticsd (1.0 - 1) <9CC64514-F654-3A1B-AECA-3F26AF210F26> /System/Library/PrivateFrameworks/CoreAnalytics.framework/Versions/A/CoreAnalytics
0x1956a3000 - 0x1956a5fff libDiagnosticMessagesClient.dylib (112) /usr/lib/libDiagnosticMessagesClient.dylib
0x1956a6000 - 0x1956f1fff com.apple.spotlight.metadata.utilities (1.0 - 2150.26) /System/Library/PrivateFrameworks/MetadataUtilities.framework/Versions/A/MetadataUtilities
0x1956f2000 - 0x19578bfff com.apple.Metadata (10.7.0 - 2150.26) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x19578c000 - 0x195792fff com.apple.DiskArbitration (2.7 - 2.7) <8C067552-F381-3760-AEC2-7638F5C5C5F3> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x195793000 - 0x195a9dfff com.apple.vImage (8.1 - 544.4) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x195a9e000 - 0x195d5bfff com.apple.QuartzCore (1.11 - 927.24) <153849B6-DC3D-3D92-9D45-7C1D2F01123E> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x195d5c000 - 0x195d9dfff libFontRegistry.dylib (309) <98642A69-7570-3882-886D-948C3BE15544> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x195d9e000 - 0x195eb5fff com.apple.coreui (2.1 - 692.1) <6980A16D-8F3F-3C98-879A-0AF6843EE57E> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x195eb6000 - 0x195f95fff com.apple.ViewBridge (553.1 - 553.1) <5484B22D-2AD1-32F5-A331-7D694C185F80> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x195f96000 - 0x195fa0fff com.apple.PerformanceAnalysis (1.278.3 - 278.3) <79F08DB3-6510-326B-9AE1-285D1A1B6D4C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x195fa1000 - 0x195faefff com.apple.OpenDirectory (11.5 - 230.40.1) <080C6FB5-2BD5-347A-96B0-B76ACA21B2B6> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x195faf000 - 0x195fcefff com.apple.CFOpenDirectory (11.5 - 230.40.1) /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x195fcf000 - 0x195fdbfff com.apple.CoreServices.FSEvents (1290.120.5 - 1290.120.5) <90A90A11-F1E7-392A-90D1-845F2E956769> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x195fdc000 - 0x195ffffff com.apple.coreservices.SharedFileList (144 - 144) <74989CAA-FA6B-3739-B4E9-2E6CD4F0680B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x196000000 - 0x196002fff libapp_launch_measurement.dylib (14.1) <933BF613-819C-33B1-9CAD-B41162C60022> /usr/lib/libapp_launch_measurement.dylib
0x196003000 - 0x196045fff com.apple.CoreAutoLayout (1.0 - 21.10.1) /System/Library/PrivateFrameworks/CoreAutoLayout.framework/Versions/A/CoreAutoLayout
0x196046000 - 0x196132fff libxml2.2.dylib (34.10) <5FAA193C-37F9-3C80-A4B4-EC335DB259F5> /usr/lib/libxml2.2.dylib
0x196133000 - 0x196186fff com.apple.CoreVideo (1.8 - 414.7) <8FE92E37-C772-3E16-A6D1-EB83A7C4DECA> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x196187000 - 0x196189fff com.apple.loginsupport (1.0 - 1) <378229DC-06F7-37C7-89B3-30670F59D022> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x19618a000 - 0x1961b0fff com.apple.aps.framework (4.0 - 4.0) <0326BBDB-3B3C-3A66-8F28-2B8FE4884934> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x1961b1000 - 0x1961cffff com.apple.UserManagement (1.0 - 1) <9D3B5D37-FF02-32A9-BAE7-8D309E4D4630> /System/Library/PrivateFrameworks/UserManagement.framework/Versions/A/UserManagement
0x1961d0000 - 0x196370fff com.apple.cloudkit.CloudKit (990 - 990) /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x196371000 - 0x1963f4fff com.apple.CloudDocs (1.0 - 738.1) /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x1963f5000 - 0x196ba6fff com.apple.CoreML (1.0 - 1) <61E26EB2-DCD0-3A66-B632-2B2D3ACC87E3> /System/Library/Frameworks/CoreML.framework/Versions/A/CoreML
0x196ba7000 - 0x1972f0fff libwebrtc.dylib (7611.3.10.1.6) /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/Frameworks/libwebrtc.dylib
0x1972f1000 - 0x197366fff com.apple.corelocation (2420.19.23 - 2420.19.23) <7A7BA9C5-FA21-310C-810D-BE32F64E034B> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x197367000 - 0x197378fff libsystem_containermanager.dylib (318.100.4) <8944B2ED-3F69-36C9-AF47-D037500AE162> /usr/lib/system/libsystem_containermanager.dylib
0x197379000 - 0x19738afff com.apple.IOSurface (290.8.1 - 290.8.1) /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x19738b000 - 0x197394fff com.apple.IOAccelerator (442.9 - 442.9) <88C4B886-3B17-38C6-816A-73105C201DEE> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x197395000 - 0x197483fff com.apple.Metal (244.303 - 244.303) <6A26D72C-978C-3174-A467-734CD0D95275> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x197484000 - 0x1974a3fff com.apple.audio.caulk (1.0 - 70) <09E0A09A-009E-3179-BE94-AA78CC751D99> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
0x1974a4000 - 0x19759bfff com.apple.CoreMedia (1.0 - 2780.10) <51760A59-F514-33BE-8B01-57DCA4F0B5AF> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x19759c000 - 0x1976f4fff libFontParser.dylib (305.6.0.2) <926296A3-5F14-3A48-A721-E6D1EBE08E83> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x1976f5000 - 0x1979fffff com.apple.HIToolbox (2.1.1 - 1062) <6DB35C0F-E17F-3B6E-B532-3B49236D1501> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x197a00000 - 0x197a17fff com.apple.framework.DFRFoundation (1.0 - 267) <23E51575-3B19-3DC4-858D-E29AA9154E99> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x197a18000 - 0x197a1bfff com.apple.dt.XCTTargetBootstrap (1.0 - 18119.1) <0F7D38FE-144C-3CDB-9C6F-447C3EED4F79> /System/Library/PrivateFrameworks/XCTTargetBootstrap.framework/Versions/A/XCTTargetBootstrap
0x197a1c000 - 0x197a46fff com.apple.CoreSVG (1.0 - 149) <88A03E2D-1252-3348-9673-CFA5B90D12BB> /System/Library/PrivateFrameworks/CoreSVG.framework/Versions/A/CoreSVG
0x197a47000 - 0x197c66fff com.apple.ImageIO (3.3.0 - 2130.6.5) <5601A5FE-BE54-3494-8CD9-2258647D7A54> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x197c67000 - 0x197f7ffff com.apple.CoreImage (16.3.0 - 1140.2) /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x197f80000 - 0x197fe4fff com.apple.MetalPerformanceShaders.MPSCore (1.0 - 1) /System/Library/Frameworks/MetalPerformanceShaders.framework/Versions/A/Frameworks/MPSCore.framework/Versions/A/MPSCore
0x197fe5000 - 0x197fe9fff libsystem_configuration.dylib (1109.140.1) <0C225C5B-FF1B-3C81-B956-2FDA13DAA7DA> /usr/lib/system/libsystem_configuration.dylib
0x197fea000 - 0x197feefff libsystem_sandbox.dylib (1441.141.1) /usr/lib/system/libsystem_sandbox.dylib
0x197fef000 - 0x197ff0fff com.apple.AggregateDictionary (1.0 - 1) <0E5213A0-A02B-3227-9BB6-0AE5A753D380>
Hi there,
This is odd. Thank you for reporting the above, and for providing the relevant information. I’ll pass it over to the development team to investigate.
Did this only happen the one time? or every time you tried to open Panda? Have you tried a device reboot?
Also may I just ask, is this issue still occurring for you?
Hi
Got your reply straight to spam folder, sorry. It is still happening, sadly I can’t use Panda at all
Hi Timur,
Sure. Not helping at all
Where is Panda situated for you?
If not in it already, could you try moving it to Applications and see if that helps?
Just did. Still crashing
We just updated to a new version of Panda today (more info on it here: Panda release notes 1.0(2343) )
Could you try this version and let us know if that solves the issue?
I absolutely could. No luck though
here is the whole report Dropbox Paper (posts here are size-limited)
Thank you for letting us know, and for the report.
I’ve escalated the issue with a member of the development team and they’ll investigate it further.
