Testing version: 2.0 (10816) MacOS,
Browser: Edge Version 112.0.1722.48
What were you doing: Pasting web links from browsers
What feature did you use: Paste
What happened: Links are pasted as markdown links as expected, but they are now decorated with underline as well (the tilde ` is added before and after).
Expected external links to be pasted as in Bear 1 (and earlier B2 betas?), without underline.
If this is intended feature, please add an option to turn it off.
“Auto fill title when pasting web addresses” in settings, still has no effect if switched off. But guess that’s on your todo list?
Update: this seems to be is browser dependent:
Safari seems to respect the Settings switch and has no underline.
Same links copied from Edge, are underlined and doesn’t respect settings switch.
Egde also gives a fuller page title in pasted links than Safari -
Copying from Chrome doesn’t give titled links.
FireFox seems to behave like Safari.
Need to restart Bear for this setting to take effect (Safari and FireFox only)
So Safari and FireFox behaves as expected.
I do prefer Edge’s more descriptive named links, except the underline.
