What’s the best way to add an existing markdown document containing that previews the image rather than displaying
Thanks
Bob
Thanks
Bob
Unfortunately, this is a limitation of the current md importer we want to work on at some point. The best advice I can get, if possible, it to convert your md files with attachments into textbundle/textpack if possible.
Thanks for your response.
Using Draft.app’ Copy as RTF or Copy as HTML.
Pasting from html leaves a blank line between paragraphs
Pasting from Rich Text seems OK.
Thanks
Bob
Bob
