Problem with tags with certain cyrillic letters (ё, й)
Testing version: 2.0 (10084)
What were you doing: Create notes with tags with some letters, switch between notes with internal links.
What feature did you use: Tags, internal links.
  • When you create note with tag “и” or “е” it appears in the list as “й” and “ё” instead
  • When you create note with tag “ий”, it appears correctly in the list. But if you create note1 and note2 under that tag and add links to each other ([[note1]] [[note2]]), every time you click the link, Bear switch to “All notes” category, instead of keeping the current tag active
  • If you use e.g. tag “бб” for them, it works just fine
What did you expect to happen: Such tag names should work correctly.
I guess that happens because Bear does some sort of normalization underneath (и → й, е → ё) but something is not right.
Thanks for reporting these problems we’ll look into them as soon as possible.
