Quoted text is causing a number of issues
See below for an examples from the editor.
  1. It seems like quote blocks can’t be stopped without a carriage return. This makes it impossible to use one in the middle of a paragraph
  2. Quote blocks are now indented (vs old Bear) but that indentation is fixed, which causes two issues:
    a. When a quote is added to a bulleted section it remains hard to distinguish from the body text (a general problem with quote blocks in the old version of Bear)
    b. Quotes can’t be used very effectively in nested lists, as they remain at their fixed indentation no matter what indentation level you are working at.
Code text doesn’t have any of these issues. Quotes should work like that.
link
