Reinstall Bear Beta
Reinstall Bear Beta
How can I get Bear Beta to re-import the contents of Bear 1.9, please? I’ve made updated in Bear and want to see how they look in the beta version? (Alternately, how do I delete the Bear beta app’s database/settings to have it re-import the database from my live version of Bear.
I uninstalled the beta version of Bear hoping the database would have gone as well, but when I re-installed the beta it has the same database from when I originally started the beta.
Thank you so much!
  • Paul
The instructions are here:
After uninstalling Bear 2, you also need to delete the Bear v2 database from Finder. Then on reinstalling Bear v2, it will automatically acquire your current Bear 1 db.
