When copying code from IDEA or elsewhere, there are some code formats. At this time I need to modify the indentation.
But when I used Shift Tab to indent, I found it had no effect. And I use Tab indentation, which cannot be replaced with four spaces.
In addition, I hope that the code block does not wrap automatically, so I can use the horizontal scroll bar to view it.
