Return to footnote anchor
It would be great if there were a quick way to use a keyboard shortcut to return from footnote text to the original footnote anchor. This would really speed up the flow of writing, allowing you to create a footnote, write the footnote text, and return to the part of the text you were working on without removing your hands from the keyboard. Obsidian has a nice plug called “Footnote Shortcut” in that does this pretty well, and which might serve as a model.
