RTL support for MacBooks?
Hey,
There’s RTL support for bear app on MacBooks?
If yes how can I activate this?
(By the way what’s the Bear beta?)
Hi there,
I can see that this is your first post on here, so welcome to the community!
Regarding support for RTL languages, the current version of Bear does not yet support this.
However, the future version of Bear will, this is what Panda is. Panda is the tester version (Bear beta) of the new Editor for Bear.
Once Panda is completed, it will be implemented into Bear via an update and Bear will gain a lot of new features - including RTL support!
Hoping this helps, but if you’ve any further queries or questions let me know.
