Scanned Documents of Lower Resolution
Scanned PDF documents aren’t as sharp as other scanning apps.
Panda - Color (100%)
Panda-Color-100
Scanner Pro - Color (100%)
ScannerPro-Color-100
Panda - Color (200%)
Scanner Pro - Color (200%)
B&W and photo formats produce similar results.
I just want to add my opinion that this a high priority. If the concern is storage space, then let users choose whether it should be high or low res?
Hi,
thanks for reporting this, I just checked and the scan result can indeed be improved compared to the results Apple Notes provided.
Regards.
