exporting a note that contained separators as Markdown
“Export note”
Separators get exported into Markdown as - - - (with spaces between the dashes) which is inconsistent with any existing standards.
All Markdown apps I know support *** and --- for separators. They should be exported as either of the two options (probably the dashes as they are more commonly recognized.)
Common mark does support- - - as a separator but I guess you’re right, --- is more commonly used. We’ll discuss changing the markdown inserted by the separator button.
