Settings: Theme previews display corrupted
2.0 (10984) on macOS 13.3.1
Via the menu bar, Bear > Settings > Themes
Settings > Themes
When you scroll down below Solarized Light and Dark themes, the previews of the themes are corrupted:
Thanks for reporting this glitch. Are you using an external monitor?
No, I’m using an iMac 27 (4.2 GHz Quad-Core Intel Core i7) with the built-in display.
I see this too!
But yes I use external monitors sometimes. And I usually see this corrupted previews after connecting to or disconnecting from external display(s).
