roar
October 8, 2022, 12:46am
1
Testing version : Bear Beta Version 2.0 (9652)
What were you doing :
Shortcut for navigation in previous viewed notes
What feature did you use :
It used to be this:
⌥⌘← Navigate back in visualized notes history
⌥⌘→ Navigate forward in visualized notes history
What happened :
Now this shortcut has been reassigned to Edit - Shift Left and Right!
What did you expect to happen :
⌥⌘← Should navigate back in visualized notes history
⌥⌘→ Should navigate forward in visualized notes history
The new shortcut is
The ⌘+⮐ doesn’t seem to work either.
BTW, did you make the shortcut list yourself?
roar
October 8, 2022, 6:44am
3
Oh, Thank you very much Eleanor, I missed that one.
No, got the shortcut list from screenshot in the CheatSheet app:
In editor:
(cont. …)
In notes list:
roar
October 8, 2022, 1:14pm
4
@trix180 @Claire_Bear @Eleanor
BTW. I actually prefer the reassigned shortcut for Back
and Forward
it’s easier on the hands and can also be done with right hand only
So not a bug – just another improvement
matteo
October 10, 2022, 9:15am
6
This is also the standard hotkey for going back/forward in many macOS apps (Safari for example), we’re trying to be as standard as possible and have expected shortcuts
