Shortcuts for note modification?
Hi folks!
I see that I can prepend and append to a note with Shortcuts, but is it possible to modify note content with Shortcuts? I can’t quite seem to sort out how.
Thanks!
ScottyJ
Yes you can: The “Add Text” action has an insert option that allow you to replace all the note content and/or the title.
Ah incredible! I suspect I was looking at the legacy actions as opposed to the current ones. Thanks so much for the pointer!
ScottyJ
