Show current header level as selected in dropdown
When I click the new header icon I get a dropdown allowing me to select a different header. I was surprised the first time I clicked one to have the header formatting removed. Turns out I selected the same header level that was already present, so it toggled off.
I don’t mind that behavior but in that case the menu should show a checkmark next to the current header level (i.e. if it’s an H3, then there should be a checkmark next to H3 in the dropdown). That would both help me to know what header I currently have, and make it more intuitive that selecting it would toggle header formatting off entirely.
Hey! This is a great suggestion, I’ll add that to our todo list :slight_smile:
Hey, you did it! Awesome and thank you!
Ah! Forgot to notify you, thanks for your support :metal:
