Testing version: Bear 2.0 test flight, iPad Pro (3rd generation) 11", iPadOS 16.2
What were you doing: drawing
What feature did you use: sketch function
What happened: after the first line or two, the response time of Apple Pencil increased, no real-time sketching was possible. Upon saving the note with the (interrupted) sketch, Bear took a while before the note was saved and visible in the list.
What did you expect to happen: immediate response to the Apple Pencil, no delay in saving the drawing
Hi @Miro ,
How do you even use the sketch function ? I am not sure if it’s because I am using an iPad mini, but I can’t see the icon that appears when using the iPhone for creating / inserting a sketch. Was there anything you did to enable it ?
I just found by accident how to access the sketch function, but hopefully it’s not the only/correct way of doing it, as it’s a bit tricky.
I order to get access to the BI U button that gives access to Sketch, highlight, etc… sections I had to change the keyboard to “Floating” and then I saw the BI U button in the lower right corner
