- Having an empty row, [backspace] (or perhaps cmd+[backspace]) should allow to remove it
- Add opt+[enter] to add new line within a row
- There’s a glitch with ctrl+[enter] – it temporarily creates a new line within a row, but it’s then disregarded
- Currently no way to resize columns
- Creating headers/footers could be nice (or perhaps an overkill?). By that I mean at least being able to color the first row differently
- Selecting a table (i.e. for cutting and pasting) does not highlight the table, only the surroundings, making it unclear if the table itself is selected as well
- Keyboard shortcuts would be great. My suggestions:
cmd + [up]/[down] – move row up/down
cmd + [shift] + [enter] – insert row before
cmd + [enter] – insert row after
opt + [shift] + [enter] – insert column before
opt + [enter] – insert column after
opt + [left]/[right] (alternatively: cmd + [left]/[right]) – move column left/right
cmd + [backspace] – delete row
opt + [backspace] – delete column
This way both rows and columns get their magic shortcut key (cmd and opt, respectively), while maintaining consistency across analogous actions (i.e. [shift] + [enter] for inserting row/column before the current one). “Opt” could be changed for “control” if it proves that it conflicts with other keyboard shortcuts, i.e. new line creation with opt + [enter]
Let me know what you think!
