What were you doing: I was editing quotes from a book and using the common convention of square brackets to indicate text added/changed from the original. For example, “[Merry] loved mountains, or he had loved the thought of them marching on the edge of stories brought from far away”.
What feature did you use: Just writing.
What happened: The text in the square brackets (“Merry” in the above example) was rendered as a link (to nowhere).
What did you expect to happen: The text in brackets should have rendered as plain text with the brackets included. If I’m reading the CommonMark spec correctly, text in square brackets that is not followed by parentheses or square brackets should only render as a link if there is a matching link reference definition elsewhere in the document (this was not the case).
Hi Janne - I suspect this is a bug introduced into the latest version of Panda. Prior to this release, putting single square-brackets around text did not result in a link - it functioned exactly as you’d expect. It looks like this current version is interpreting [bracketed text] as something akin to a footnote. If you click the link, you’ll see a new footnote created at the end of your text. Proper markdown footnote syntax is [^1]. So as I say, I suspect what you are experiencing with [Merry] is a bug that will soon be fixed.
If I understand the vision for Pandas correctly, then it will be a fully common-mark compliant editor with some Github flavour. The [foo] turning into a link is expected behaviour given the spec see (GitHub Flavored Markdown Spec). It is different from the [^foo] syntax because the former is a hyptertext link that will open a browser (or a the relative url-handler) whereas the latter is a footnote, it will navigate to the position where the footnote is specified.
[This one] is a link because it has a reference definition below.
[This] is not a link because it doesn’t have a reference definition.
[This one]: https://beta.bear.app
I think you’re right that it comes down to expected UI behavior, rather than spec conformance. Personally, I would prefer square brackets to be left alone unless followed by parenthesis for two reasons:
By default, Bear does not use the reference link notation in its Markdown output, opting instead for inline link notation
Unlike footnote notation ([^…]), reference link notation ([…]) sees frequent legitimate use outside its use in links
I can see that this is your first time posting on here, so welcome to the community!
This falls under the age old question, is this a bug or a feature?
@sitacuisses was correct, this is in fact expected behaviour and is a feature.
This is as it’s part of the CommonMark specification. A single word inside [] is a link reference, it should be paired with the link definition (which is usually at the end of the note).
Currently, we’re marking that as a link because clicking on it auto-creates the definition.
The current UX however is not ideal because it’s annoying if you just want text inside parenthesis.
Therefore, we’re working on changing it to highlight only if both reference and definition are present in the text.
Hoping this answer helps, but if you’ve any other queries or questions please do let me know!
