Suggestion: copy to clipboard button on code blocks
I’m using code blocks as a way to store, well, code snippets. It would be really useful to have a copy code to clipboard button on the block, save me messing about scrolling and selecting long blocks.
thanks.
@kimaldis you can right click and “Copy code”.
Having said that with the new version of Panda the code syntax is hiding (which I find visually appealing :+1:) and it’s a bit more disruptive to copy the code block. In general this is far from ideal with right click because it almost always does some random selections.
