Testing version: 2.0 (10816) MacOS
What were you doing: Checking Sync status and Settings to disable sync
What feature did you use: Sync icon (and hamburger menu) on top of tag list
What happened: When you hoover over Sync icon, tooltip “Preferences” appears,
When you click on it, Settings panel open.
To see last synced time as tooltip, as on iOS
Clicking on it, expected to see last synced time, and settings to disable sync on Mac as on iOS
Tool tip says “Preferences”, also on hamburger (with pickles) menu next to it, but menu call it “Settings”, Maybe it should be called Settings for consistency?
Guess both icons opening Settings is an oversight?
Tag sorting options seems to be missing from new setting panel?
