Testing version: 2208
What were you doing: Copying table from other markdown file
What feature did you use: tables
What happened: If there is a tab character in the | --- |
section of the table the table does not render. This is not an issue with other “content” cells. GFM renders the tables correctly even with tabs.
What did you expect to happen: the tables to be rendered even if final chacater is a tab, i.e. it is treated as a space character.
