Testing version: 2.0
What were you doing: Tabing and trying to indent, make paragraphs.
What feature did you use: Not sure what the feature is called that highlights it like that.Can’t find it in Bear 2 or original Bear notes.
What happened/What did you expect to happen:
Tabs at the beginning of the line are interpreted as code blocks within the common mark syntax. You intend always used tabbed paragraphs you can check the typography preference.
I don’t get the first part
When I tab on the next line like this
and then type, it doesn’t tab, but jumps back to the beginning of the line.
Can you please make a quick video?
thank you for responding. Hopefully this clarifies. I looking for paragraph indents to be an option for each paragraph within and document, not just a default for all of them.
