Version 1.0 (2595) for Mac
Adding a separator between the top of the note and the body. I usually keep tags at the top of a note, separated from the body of a note using a horizontal rule / separator
I typed in a tag, and then below it added a separator line.
The tag suddenly assumed the size and format of the header. rather than the default tag text size and format.
Tag size should remain the same, as it does in Bear. The file format in both cases is markdown (.md extension). In panda, the tag gets formatted as if it were a header, rather than a tag. I’ve included screenshots to show the difference.
In Panda:
In Bear:
I realize this might be expected behavior due to the switch to CommonMark, but it seemed worth reporting, just in case. Bear’s behavior seems preferable to me.
