Tags in highlights
Hello Bear! Is there a planned visual element to differentiate tags in highlights?
  • Bear does this by ignoring the highlight
  • Panda simply overwrites the tag visualization.
I prefer Panda’s rendering, but still would like a visual que of some kind, maybe an outline of the tag allowing for the highlight to show through the tag background? (See third image… tag outline of corse would be with rounded corners)
Hi! Yes, totally make sense we prioritize tags over highlighting in this case as the tag has to stand out even if highlighted. I think we’ll go with Bear solutions mostly because I suspect having two different representations for highlighted and non-highlighted tags might be misleading.
Thanks makes a lot of sense. Thanks for sharing! :teddy_bear::+1:
