What were you doing: I used the tap and hold to edit what Panda interpreted as a link. In my document I have a section of text that uses brackets and parentheses used to denote reconstructed text in ancient artifacts. In my document I had O[mr-](i)
which in the video you can see rendered as Omr-
on the far right mid way down through the window. I wanted to see what the tap and hold function would do with this.
What feature did you use: Tap and Hold to access “Edit Link”
What happened: The pop-over window didn’t display correctly, and was overly narrow, perhaps only 10-20 pixels wide. (See video)
What did you expect to happen: To be able to see the full pop-over window to edit a link.
