Testing: footnotes in Bear
As it can’t be directly tested in Panda:
  1. Wondering if actions resulting from selecting a tag placed in a footnote would be the same as when it is placed within “regular” text.
  2. Wondering if an item clipped/shared and appended to a Bear note will append ahead of or after existing footnotes.
  1. yes, tags are valid inside footnotes and they behave normally.
  2. if the footnotes are the last thing in the note, we’re probably going to append the text before them.
Best.
