After Version 2 goes live, we need a Things 3 integration…
Hi Dan,
maybe the “Bear tasks to Things” shortcut might be of interest to you.
Thank you @max I will definitely give that a try. What I would love to see is that if complete a task in Things, it would complete the connected task in Bear. That may be way to complex to accomplish, but its fun to dream.
Here is another shortcut you may use or modify to your needs:
Creates new Bear note with selected photo and links it to new Things todo item in Inbox with link to Bear Note in to-do item note field. Links both ways.
Great, though I may be missing something. The Things items links to the note, but I only find the #things tag in Bear but no link
Just Below Title
[Link to Things To-Do]
Not in your bear note?
Are you on Mac or iPad? Both should work …
It does now, using the share sheet shortcut. Great job, thanks
(Both mac and iPad)
That’s from an earlier version, where instead of creating a new to-do in Things, it just copies bear link to clipboard and open Things in it current view/todo item, that you may already have, and you just paste link into existing todo note field manually.
But then a couple of new actions above should be deleted/deactivated since they now would be redundant. And I didn’t get the two way linking in that old version.
I often insert Quick View and Stop Shortcut actions different places in code under development and testing to see what’s happening midway somewhere. It’s a clunky way in lack of a built in debugger.
