Todo submenu in style bar always greyed out + "toggle todo" shortcut not working
Version 2.0 (9652)
Trying to toggle a todo into a completed state while the cursor was on the same line.
The “lists” submenu in the style bar.
All the submenu options except for “todo” were greyed out. The shortcut listed there (Cmd+.) also did not work. (However, the same options in the top menu Format->Todo worked but there was no shortcut listed next to the “toggle” option).
I expected the submenu and the keyboard shortcut to work.
On a side note, Cmd+. is a terrible choice for a shortcut since it’s equivalent to pressing ESC on the iPad so it would clash with that. It would be better to pick another shortcut.
Thanks, we’ll see what’s going on there!
