Toggle through Search-Results
Hi from Germany :slight_smile:
Lets say i have a very long document, eg. it takes 10 minutes to read. its a document where sometimes i tagged something mit #idea
when i search for #idea it finds this note an highlights the #idea yellow, which is perfectly fine. is there a way / shortcut with that i can jump directly to the next search result of #idea. otherwise i have to scroll through the whole document to look if there is perhaps another result. and the other results would not be highlightes yellow but grey. thats sometimes not easy to see depending on which theme you use.
thx
macOS:
  • search for #idea
  • TAB
  • :leftwards_arrow_with_hook:
  • ⌘ + F
  • :leftwards_arrow_with_hook: to go through in-note results
iOS: search for #idea, select note, menu > search, select search (bottom right) to go through search results
Be careful not to hit TAB while you’re scrolling through the results using :leftwards_arrow_with_hook: or you may accidentally delete the tag.
Perfekt :slight_smile: Thank you
