Toggling headings without blank line separation
Testing version: current
What were you doing: adding heading points with lines of text following with a blank line added after the text lines under the first heading
What feature did you use: toggling
What happened: each of 2 headers with text under each toggled as expected… each heading on its own line. I remove a blank line after last line of text under the first header, both headers where then on the same line.
What did you expect to happen both headers would remain on their own line
Thanks for reporting this bug. I simulated the bug scenario but just to be sure, the “first heading with…” heading ends with a list?
nevermind I got the screenshot now :man_facepalming:
