Trying to return between two immediately written wiki links
Testing version: 10209 Bear 2.0
What were you doing: trying to move one of the wiki link to the next line
What feature did you use: pressed return
What did you expect to happen: return and move the second link to the next line
Workaround: create space and then return
There is also a bug where the space bar does not seem to create a space but when in editor-only view, it shows the right amount of space. But this one does not occur all the time so I am not sure of the trigger.
Hi Eleanor, do you mind sending the note in the video for tests?
It basically works with any hyperlinks that are next to each other without space.
e.g. [[note1]][[note2]]
Archive.zip (3.3 MB)
The testing note is testWelcome to the Beta! note.
got it! thanks for reporting this issue.
