I imagine this is to create a separation between bullet points + todos…but is there any way to undo this? I had gotten pretty used to the 1.0 way of hyphening to create to-dos as part of my workflow.
Thanks! Otherwise, 2.0 is incredible.
No, the feature you mentioned was called Polar, a format made by the Shinyfrogs but abandoned it in favour of the CommonMark standard. You either have to use the shortcut or the button now. Or type - [ ]
