Typography and display size
Maybe to early to ask?
  • But I’m missing zooming font size Cmd + and Cmd -
  • Setting fonts implemented yet in this beta? Could not find it in settings …
Hi there,
those settings are not exposed in the beta, but they will be there :slight_smile:
Best.
It’s hard to test and read on mobile phone with this font size typography. Is there a way to set it bigger ?
The Panda Editoa Beta (Alfa) is getting better and better, but I sorely miss the option to zoom in/out on font display size.
The current fixed size is way to small for me, both on MacBook Pro 13" and iPad/iPhone.
Please integrate the typography options, also in this Panda beta – should be part of the editor testing, I believe :nerd_face:
If the full Bear beta is just around the corner, then fine, but otherwise asap :wink:
:panda_face::bear::mask:
