Unlocking note in MacOS
Testing version: Version 2.0 (11164)
What were you doing: Unlocking a note that was created in the previous version of Bear.
What feature did you use: Entering password to unlock
What happened: App crashed
What did you expect to happen: Unlocking of password protected note & ability to see content.
Same for me. The app crashes even if the note is created in the beta. The issue seems to only occur in the desktop version.
Please check update 11165, should fix this issue.
