Testing version: Version 2.0 (9652)
What were you doing: Checking for updates.
What feature did you use: “Check for updates” in Bear menu
What happened: Error message pops up
What did you expect to happen: A message that says there aren’t any updates yet.
Perhaps move your app to the application folder and try again?
krssno
3
The moving to the application folder was too tricky as already the bear 1 was there. I just moved the app file into another folder and then it worked.
I just selected keep both and the new Bear2 was in as ‘Bear copy’ and works fine. But if moving to any other folder works, then that is good I guess.
krssno
5
Somehow that seemed too risky for me
I did that before and it still didn’t work. I quit it again and restarted, and now it works.
BTW, I renamed the app Bear 2 without problems.
Thanks,
Erik Vlietinck
Freelance journalist and content writer for Fortune 500 companies and SMEs.
