Use - to create a task
I used to be able to start a new line with - and it would create an empty check box. Now it creates a bullet, similar to *. Is this the intended behavior? Would be nice to have an easy way to create a checkbox from my phone
Bear 2.0 is now using CommonMark flavor of Markdown. And the - will create a bullet. https://commonmark.org/
