Quick question: Can someone tell me where Bear 2.0 stores notes right now?
I managed to create a rough note that I can’t delete or edit because if I try to do it, Bear 2.0 force closes. (Don’t ask me how this happened. All I did was put a * infront of a code block and somehow it crashed the app.)
That was my idea too but I have no clue what happened. The interesting thing is, when I try to view the note it’s content isn’t formatted and instead it’s shown as:
# Test test
* Example:
docker run -I \
-v "$(pwd)":"$(pwd)" -w "$(pwd)" \
djithermal
Hi Matteo. Inside the Application Data v2 folder I have a database.sqlite and Local Files. Local Files only contains a folder called Note Images … ? xD
And I tried to export the note via Bear but every time I try that the app force closes. So for now all I can tell you is this: I had a nested list and inserted a code block below it. Then I wanted to try what would happen if I tried to make the code block a part of the list. So I inserted a * right before the ``` and that killed the app and the note.
